ian
Problem: My engine vibrates excessively (in my uneducated opinion) could send vid._crack in 2 " diameter diagonal frame member under radiator area(drivers side). check engine light comes on for a day or 2 and then goes out. unplugged wire harnesses every where. already stalled a few times. so installed the PMD isolator, new cdr, and lift pump, i have a TurboMaster in the box, and the new computer from heath is on the way.(more at bottom) __________________________
- Year: 2000______
- Truck model and class (ie: c2500) GMC 3500 crew cab _________
- Automatic or Standard: auto__________
- Mileage: (indicate miles or km) 82,600_________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _pmd isolator, idles at 1000 rpm drops when foot on break__________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? "f" engine turbo (EGR ???)______________
- Ambient outside temp: (indicate *C or *F) 36* F__________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) #_1 (i think)________
- What fuel additives are you using? ___________
- Where are you located? __Juneau, Alaska___________
- Air filter _dont know________
- Fuel filter _dont know ________
- CDR Valve? _March 2010________
- Coolant – last flushed/replaced at _dont know____________
- Oil – synthetic/regular, changed at _regular Mar 2010__________
- Batteries – state of charge, (matched set) replaced at _dont know____________
- Battery cables and grounds (removed, cleaned and tightened): __dont know____________
- Glow Plugs - how many miles on them? _dont know________ What type? _____________
- Injectors - last changed at _dont know______________
- What were you doing when it happened? ______________
- How was the truck running fine before this problem appeared? _____________
- Has this problem ever happened before? _______________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __Y__ And? 1)ignition pump cam system code P0251
2)turbo charger boost performance P0236
3)fuel seliniod response time P1216
Diagnostics:
1] Starting:
1a] Does the engine start? __Y_______
1b] Does the engine crank over? __Y______
1c] Are your batteries fully charged? __Y_______
1d] Have you removed, cleaned, and tightened all battery connections? ___N_____
1e] Does your Wait to Start light come on for a time? How long? __Y_______
1f] Does your glow plug light come on? ____N_____ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? ___Y white_____
1h] Does the Service Engine Light Glow during Start/bulb check? ___Y_____
2a] Can you hear your lift pump working? __N_but i just replaced_________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? _____Y______
2d] Loosen an injector line and crank the engine - does fuel come out? _____dont know____
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? _____dont know______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _front skid plate__________
3b] Condition of Extension harness (if used) Vendor or Homemade? _____new____
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ___dont know______
3d] PMD Make: __heath_________
3e] PMD Age: _____new________
4] Stalling Issues
4a] Do you experience stalling only when hot? __n__________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _n_____
4c] Does pouring cool water over the IP seem to help with restarting? ____n_____
4d] Is stalling momentary (engine recovers)? __n_______
4e] Does SES light come on when engine hiccups? __n_______
4f] Does cruise control quit working when engine hiccups? __n/a_________
4g] Does re-starting seem to reset engine, restoring cruise and power? ____n/a_____
4h] Changes to dash lights or instruments during stalling events? ____n_______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? __dont know_____
5b] Any bubbles or oil film in coolant overflow tank? __n_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _____n_____
5d] Excessive white smoke from exhaust on cold start? __Y_______
5e] Excessive black smoke from exhaust under hard acceleration? _____N_____
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ___N________
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? _not yet_____________
6d] Have you changed exhaust / downpipe / crossover? _n_______________
6e] Wastegate – mechanical or vacuum (OEM)? ___vacuum___________
7a] Single or dual thermostats? ____dual________
7b] Have you replaced them lately? Manufacturer of replacements? __no_______
7c] Have you pulled and cleaned Radiator and coolers lately? ___no_________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ___no_____
7e] (winter) Have you tested your antifreeze? Good to what temp? ____no______
7f] (winter) Are you using a winter grille cover? _no__________
__I just bought my first diesel and want to make it a dependable and powerful towing rig for years to come, but i believe its been neglected and mistreated for a decade. Help me prevent it from blowing up!!!___thanks in advance Ian____________________________
__________________
- Year: 2000______
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
__________________
