HighSierra86
Active Member
Ok guys, I need some help here. We have a 2000 chevy express van with the 6.5. Yesterday it started acting up and im having some trouble figuring out what is going on.
One of our guys was out on the road and it went into limp mode with an SES light. Limped it back to the yard where I got to look at it. Found code P0251 in the system. I took it for a ride to check that it was in limp mode...it started and idled fine but as i started driving the RPMs suddenly raced up like my foot was to the floor. I dropped it into neutral and coasted to a stop, where it shut off shortly after. It restarted right away and i drove it back to the yard.
I checked fuel pressure and found none at the t-valve (or in this case a pressure tap? must be a newer model thing for a quick disconect guage). Found I had power at the lift pump but no pumping.
Replaced the lift pump with a new 93' model. Van started right up, with a nice smooth idle. But now, any increase in throttle leads to a large surge in RPMs. With the pedal in any position over idle, the RPMs will hunt up and down consistantly, in drive or in park. :confused5:
This truck is on the original IP at 130K miles. PMD has been relocated with a heath unit behind the bumper last fall. Mind you that exact unit has been on 3 other trucks over the last few years, but never any issues.
The only other clue I have is last year (before the PMD replacement) I had it throw the P0251 code again and go into limp mode. I cleared it, and nothing came back until now.
Any tips or hints would be greatly appreciated..I was wondering if it would be worth it to swap in another optic sensor? Everything, and I mean everything on this truck is a royal PITA to get to due to the engine being stuffed under the dashboard. Thanks for any help guys
-Nick
-Nick
