Close to losing what's left of my marbles. Been fighting problems in my engine harness since buying my truck almost two years ago. Kept getting error codes 13, 17, and 18 for fuel solenoid and optical sensor faults. Thought I had it tracked down to a bad I/P - replaced it and still had the codes. :mad2:
After climing around and checking the harness, I got the codes to go away when I got into the harness connector at the rear of the block. Seemed like a couple of wires were making bad connections, I bubba-fixed-it with a couple of small finishing nails jammed in the back of the connector to help the male and femal ends meet up. Worked great - thought all was behind me! But...
Last October started a really bad oil leak. After much time cleaning and checking for the source, would have sworn it was coming from the driver's side valve cover gasket. Took the top of the engine apart, put back together, now I not only had a leak but those damned error codes came back.
Finally got oil leak taken care of today - was oil cooler line, but at wits end on these codes.
I went through and cleaned every ground at the start of this saga, and plan on doing again. Would greatly appreciate any thoughts and ideas, and if anyone has a spare harness lying around, I'd be willing to try it.
Thanks for the chance to vent.
