GM Guy
Manual Trans. 2WD Enthusiast
hey all,
I am looking at a project pickup. white 6.5L 5spd, 4wd this time. IDK what I am going to do with it if I buy it.
if I fix it up some to use as an on-road pickup, I got a problem.
it looks as if the cutting torch was a removal tool for the flatbed or gooseneck plate, and its left with this:
has anyone here welded on a GMt400 frame? I know on our Semi trucks, they seem pretty concerned about welding on frames, I assume due to it being a higher carbon content? are these frames pretty forgiving as far as patching, welding, etc?
I was thinking of getting a piece from my K2500LD junker, but am concerned about frame thickness. they are different in thickness, correct?
as far as strength, how weak would this be even after being repaired? I may be putting a B&W turnover ball on to add some strength in the area.
Finally, if I ever want to find a donor frame, I should be OK with one from a automatic gasser, correct? as long as its a K2500HD RCLB? Is there a way to tell with the plastic label on the right side towards the front under the cab? I think its a 3 letter code.
any input appreciated, thanks!
