orrum
Hello again, sure hope yall r not gonna black ball me for talking too much. What I am doing is converting my truck to a single tank wvo blend. I need two fuel filters in addition to the factory square one. I am getting a Walbro LP and adapter fittings from Leroy, Burning Oil, when they come in, I am mounting it in place of the stock LP and I need a prefilter so thats one I need. The next one I want to install in the engine compartment sorta over the exhaust area to get a little heat, I want this one to be 5-6 microns and the prefilter 30 or so microns. One of these has to be a water separator, it does not have to be with a drain but preferred. I can get 1-14 thread filter mounts really cheap from a friend but am willing to use others. I can get a 11/16-16 mount from Walmart very cheap with a 14 micron filter water separator very reasonable but its small. Can I put a 3/4-16 filter on the Walmart mount? I want a good sized one to take longer to stop up. The wix filters I have stumbled on r very expensive for the water separator type, like $23 and the wvo will clean all the crap out of my tank, lines etc and stop up a bunch of filters at first plus I like to change the fuel filters at each oil change @ 3000 miles to avoid polymerization of the oil caused by the wvo. So I would like very reasonable priced ones. I can get a 6 micron non water separator Wix for $8. I will use any combination it doesnt matter where the water separator one is installed. I cant use a water block filter tho because wvo reacts with the water block and stops it up even when there is no water in the fuel, dont understand the way it happens but take my word after running my Mercedes for 10000 miles on wvo I know how fast a water block plugs up.
Another option is Deere ( Justin) has a 6.5 stock filter for sale, I could use it and possible rig up the water sensor and fuel heater to work, that would be great but I have questions about that. One is what micron rating filter can I get to put in it? Do any of u electrical genius think u can talk me thru how to wire it up to work with the sensor and heater, the heater would be really nice? Dont need a lot of heat with my blend but any heat is good heat. Most important question is the Feed The Beast mod says the 6.5 fuel manager has to be drilled out to get good fuel flow, so what to do about that? Dont think I am qualified to do that. Thanks.
