racerallmine
- Messages
- 2
- Reaction score
- 5
Just did a full overhaul on 96 chevy 6.5 turbo deisler cant get it started have fuel all the way to the injection pump but nothing to the injectors
Thanks will try itWelcome @racerallmine verify you have fuel pressure from the LP and the air purged from the filter. then make sure that when you have the key on, the fuel shut-off solenoid has power at it's connector. if all is good, it will take quite a bit of cranking to see fuel at the IP lines at the injectors. leave the line nuts loose on the injectors and crank away but with good hot batteries.
don't overheat the starter. crank in cycles of 30 seconds crank, 30 seconds rest, 30 seconds crank, then let it rest and cool for 30 minutes while the batteries are on the charger. once you see the line nuts begin to leak fuel, tighten them up and it should start up, stumble a bit and then run.
whatever you do, do NOT use starting fluid!
/\_/\_/\_ WHAT HE SAID _/\_/\_/\Pull the glow plugs til to release compression and the engine will turn over faster and not so much strain on the starter.
