Need brush kit for Bosch Motor Fisher SEHP MM1 Plow
Matt Bachand
Depends on the 6.5
Worcester, MA
Found #56665 from fishers website PDF file, can't find that available ANYWHERE to purchase on teh web.
On my bosch motor it reads
9 130 450 099
I need the brush kit. One of my brushes was cracked and fell apart on re-assemble. I wirenutted it off, and the motor runs fine with 3 brushes, but I will not run all winter like this.
Found a new motor for 120 after shipping, or 130 local, but rest of motor looks fine inside, if brush kit is cheap, i'll just do that. But having serious trouble finding this online.
Matt, never have found a source for the brushes. I have those in a new motor for around $110 delivered to you if you can't find it. Bet you are glad you started early.
I'll probably take you up on that offer. I have it running fine off of 3 brushes, but I can't trust things like that. Good spare I guess. I'll try Napa, but I'm really leaning towards new.
Didn't know you dealt Fisher products. I think I'm going to need the Pump to Motor Seal also, which doesn't come with the motor I assume, as I think it's the same motor for Insta-Act and SEHP (which I have) and I think they are 2 different seals.
Let me know. The Seal I might not have, but I get deliverys in bout every 4 days.
I may be wrong about that seal. It may be in the motor as it may be unique to the SEHP unit.
I'll get the motor without the seal, and get seal afterwards if need be.
I'll send you a PM. Although I'm sure you'll have read that before this.
