Rodd
Recruit
Now that soccer season is over I scheduled this weekend to do some upgrades to my truck.
1. Feed the Beast
2. Racor
3. Down pipe and Crossover pipe
4. Gauges - fuel pressure, turbo, and EGT
Is getting 1 out of 4 bad?
I started w/ the dp and xover since I thought those would be easiest. Was I wrong. :mad2: The xover was easy. The dp was a pita. Penetrating oil my butt. Nothing penetrated crap. I sprayed penetrating oil for the last week on the bolts where the dp meets the rest of the exhaust system. They wouldn't budge. So I sprayed more and decided to tap the upper intake for the turbo gauge. Putting it back on I thought I would check the torque settings listed in tech library. I read the intake at 43 and stripped 2 of the bolts. I had to tap and modify 2 bolts that I had so they would fit. Finished that and went to the dp I broke 1 bolt and got 2 others off. The last on (top closest to the body) would not budge. I tried my propane torch for 5 minutes just heating it up and nothing. The only thing I had to get up in there was my dremel. It went through 10 cut off wheels. When I got 1/2 way through I thought my impact wrench would break it off. No luck. I got about 3/4 the way though and nothing. I grabbed it and started shaking it back and forth, stuck my big screw driver in between and tried prying it and nothing. Shaking it back and forth finally did it. It finally broke. I think it may have been tacked at the top of the nut. It didn't look like it but that is what I think. Then putting in the DP I realized I needed to remove the xover in order to get it in. More work :mad2: Didn't get to finish anything else. I guess I do the gauges this week and the fuel stuff this weekend.
1. Feed the Beast
2. Racor
