88gmctruck
02GMCtruck
So, last Friday after classes my truck started making a very weird clicking/metallic sound that I have never heard before. It was very prominent and changed with speed and also load. It also developed a noticeable vibration. So after a quick parking lot drive-by diagnosis, it was determined that it was coming from the rear of the truck. My first thought was the G80 was about to bite the dust (between the original truck it was in and mine it has over 300k). It was suggested by Devin to check the U-joints as well.
So, the next day up on jackstands it went. I had a friend "drive" the truck while I first listened to the rear diff.... no sounds inside there. So I moved forward and listened to the transfercase area. I could hear the sound towards the middle area, and saw the driveline moving out of round. So I checked the U-joints. The rear Precision 447 conversion U-joint was "loose", however the front spicer joint felt fine. After replacing the rear joint, i moved to the front one which seemingly felt good. I'm really glad I looked close, because it was far beyond good.
Only 1 of the 4 shaft/caps had failed. Something must have clogged the grease passage at some point in time, because it obviously had not gotten grease and was burning up. Notice the cracks in the cap, and ground up needle bearings. The only indication from the outward appearance that the joint was failing was the cracks in the caps itself.
Prior to diagnosing the sound, I was 99% sure the U-joints weren't bad, as they were barely over a year old and greased regularly. I literally had inspected and greased them during thanksgiving while the trans was out. I also think the conversion joint started to fail because this one was, as it was properly greased as well, and had VERY little play.
