Veg_Out
Walking J Designs
Hello all,
I have had an oil leak on my Burb for a couple months now, and every week or so, I replace a seal, or a part thinking I must be correct.
Here are the symptoms. Drive for 5 minutes, no leak. Drive for 10 minutes, pancake sized leak, quickly too. It's dripping out after shut down pretty quickly, then stops. One pancake's size leak, then no more dripping.
1st thing I replaced was the Oil Pressure sensor since it seemed as though oil pressure was causing the leak. As soon as it leaked off, voila, no pressure in the sensor, but to no avail, still leaking.
2nd idea came from a friend of mine, change the seals in the 4WD adapter. I thought for sure this was going to do it. I got her all bolted back together, and drove for 5 minutes, no leak. Jumped up and down with joy in a parking lot. Drove home, looked again, and my joy turned to sorrow in an instant. (I must admit I swore loudly.)
3rd thought was a stretch I'll admit. My fuel manager was leaking, so I thought it must be leaking a bit under pressure, picking up oil in the valley and down the back of the motor (running B100) and making it look like an oil leak. So I rebuilt the fuel manager. While this was not fun, it was educational (a new thread on that shortly). My fuel manager now holds fuel pressure alot better, but the oil leak has not ceased.
I'm down to possibly 3 more ideas. Valve cover, running then through the valley and down, turbo drain tube seal and of course, the dreaded rear main.
Your thoughts are welcomed.
