SnowDrift
Ultra Conservative. ULTRA!
What are the recommendations on this?
Is it best to mount the turbo onto the exhaust manifold and then install the adapter flange from Quadstar with the 5 bolts between the turbo and the downpipe? The LH rear bolt is giving me a LOT of trouble - simply cannot access it. If I run the bolt up from the bottom, then I can't thread the nut on because there is no room to get my fingers in there to work. The studs on the OEM turbo were convenient.
