treegump
Romans 3:22-24
and maybe in the wrong thread...but...How is a K3500 different from a K2500. Is it possible to make my sig. into a K3500 (or rather - a 1 ton truck)?
Fleetsides I think it is just the springs. But dually's have different rear axle. There are a couple guys here that put 3500 springs on their 2500. On that note just about any thing can be done.......I put 3/4 ton truck springs under a K5 blazer I had. Did all four corners I had to change the shackles too though.
A lot of that depends on your 2500... Is it an 8-lug axle or a 6-lug?
Do you have a full-floating rear end?
What size are your rear brakes?
On the heavy-duty ones (like mine), you need to pull the rear axles out before you can pull off a brake drum, and it is a big, heavy SOB.
