FellowTraveler
Well, this morning I noticed my brake pedal low checked the brake fluid level and the rear reservoir port for the front brakes was was dry and underneath it looks very wet like I have a leak between the hydroboost and master cylinder cleaned it up could not find any lines leaking so suspect rear seals at rear of master cylinder because I have a leak between it and hydroboost any of you know of a master cylinder upgrade or?
I had thought the leak between the brake master & hydroboost was the booster piston seal but it is not booster-p/s fluid level is where it should be. This is the original master cylinder & rebuild my own hydroboost when needed.
