Mahle LB7 Stock Piston Kits
Status
Not open for further replies.
ripmf666
Registered user
Kansas City Mo
$1,400.00 shipped
LB7 Stock Piston Kit Std. Bore Set of 8 pistons come with rings, pins, and clips.These come stock as 17.5:1 compression and were used in the 2001-2005 LB7 and LLY best used to replace the LBZ and up pistons with or use in stock overhauls.
Available in the following bore sizes: std, +.020 and +.040
Can also come with bearing sets or if you want full gasket kits and new cams lifters and oil pumps.
Status
