lowering a 94 C1500 front end
buddy
Active Member
California, central coast
Anyone have suggestions on lowering the front end a couple inches. I put on slightly taller tires and so its up a little higher now and its mainly used for commute to work and highway in general, not off road stuff. The truck is level now front to back, and I dont mind having a slight angle up in the back, so wasnt planning on lowering the back.
If it matters, not sure it does or even if its true, but dealership paperwork from PO said it has 2500HD towing package, so it has 5th wheel bars in bed, and electrical connections galore for trailers, airbags on the rear springs and was originallly used to pull a horse trailer.
You can get lowering spindels. Belltech and others make them. Summit racing has several different brands. Better than lowering springs because you keep your front suspension geometry and spring rate. Lowering springs usally are a stiffer rate. I want to put them on my monte ss.
