matuva
Tropical 6.5er
Good day all,
I have been given a complete front end from a 1995-1996 K1500 truck.
I so should have the opportunity - if doable - to swap the lower control arms to my 1994 BLAZER.
My BLAZER has the "riveted / bolt-on" pattern lower ball joint,
as the one from the truck gets the "press to fit" ones.
Other than that, the lower control arms look similar, and according to the part catalog, they do share the same bushings.
Question is : does anybody can tell me if these lower control arms will interchange? It seems they should, but if I can get confirmation
that should potentially save time and pain
If they do, this is perfect: I could prepare the new control arms, so once ready, I just have to pull the "old" ones and replace them.
