Big T
Do you need a torsion compression tool to get the Control Arms off? Once I get them off, I'd take them in to have old bushings pressed out and new ones pressed in.
You can use a floor jack to release the tension. Seriously I would recommend subbing this job completely out to a local suspension shop. I did it once with help and the second time I hired it out - it took em a week to do it. You are grinding bolt heads to slip it past the diff to get the lower control arms out.
