matuva
Tropical 6.5er
on a 1996 K1500 with the 6.5l engine.
I'm not sure, but it seems the mechanic did something wrong on the front axle when replacing the output shaft seal of the front axle, passenger side.
To replace, the seal, he just pulled out the shaft, replaced worn seal, and then replace/push inside the output shaft till it gets back in place.
Did he the things right or did he made some mistake? Is it possible something felt inside (e.g. fork, shims, etc....) or no way it can happen?
