tanman_2006
Just a farm kid...
Ok, now that I have both my 95&93 on the way to being up and running for a summer of work Chit has hit the fan it seems.
My 95 is loosing coolant and the oil level keeps going up.
It still sounds and runs great after the smoke show on start up goes away. It is a 506 block (not sure if it is navistar yet), installed by GM in 01 or 02, and has ~170,000 on it. Doesnt tow very often at the moment but does have a chip from buddy i enjoy using. Has 42psi warm oil press at 2000 rpm uses maybe 1qt of oil/5000 miles and gets 16-17 in town and 19 highway.
IF it is a simple as a head gasket I will get a thicker gasket and studs which means I will need to pull the engine to get the studs in easier (i know it is possible to do it w/o pulling the engine but my my tranny is slipping and the firewall mat needs replaced).
So while I have it out my thoughts are I might as well build the engine to my liking which isn't gonna be cheap.
If I have a cracked block then??? Sleeve it if it is a radius crack in #8 and trash it if the mains are cracked through.
I have a block that siezed from lack of oil sitting at the farm that i might check the mains on and rebuild if it is ok but it is a GM 506 block from a 99 3500hd.
If i decide to build an engine it will get:
Splayed mains
18:1 slugs (kennedy)
possible Penninsular roller rockers
VGT 351 or HX40
and all other basic replacement parts for an engine build
Keep in mind the final goal is a SAS lifted mud and trail truck not a DD. There aren't many 6.5's in the offroad world so I want to be different. I know that it is going against the purpose of a diesel truck.
Hope you all can sort your way through my post. Any thoughts are welcome!
Splayed mains
VGT 351 or HX40
