1) I'm thinking a PCV reroute is in order soon. Pretty sure Joe had a simple method he used.#1 is the oily goop from the PCV oozing out of the boots. Mine stopped completely once I re-routed it and cleaned the connections off.
#2 is your hydroboost starting to go south. Mine looked like yours and then started leaking and leaving drips everywhere before I replaced it.
Sure Mike. I will get some pics tonight when I get home. Its not to bad to do just a little labor.
Parts list:
Aproxx 6' of 5/8 rubber heater core hose
1- 5/8" coolant hose tee. Usually made of higher temp plastic
5-worm gear hose clamps
1-1" rubber chair leg cap. (iirc its 1", its been a while)
The factory pcv pipe has metal ends that bolt to the valve cover, I cut the crimps where the metal meets the rubber and reused the metal ends so they seal nice to the valve cover, and they also seal nice to the new rubber tubing because they have the factory flare in them.
From there I got 2 pieces of iirc 5/8 tubing about 12" each, slide them over valve cover tubes and clamp. On mine I fit the tee a bit favored to the pass side for outlet tube routing. Adjust according to your own perogative. From there I set up the the tee as I saw fit, and slid the hose on and clamped. The output hose I ran tilted back towards the fire wall across the a-c accumulator then tucked behind pass battery running down the firewall behind the fender liner. It ends on the bottom of the truck and I have mine zip tied to the inside rocker panel pass side. I have never gotten a drip out of the thing.
I had made a filter to catch the oil but since no drips I never put it on. It does put out some smoke when the oil is hot after a long run or towing. More of a steam not a burning oil smoke.
PICS COMING TOMORROW MORNING
