ripmf666
Registered user
LLY 3" ProFlow Bridge $ 447.00 Shipped quote is to Continental USA Only Coating is $ 35.00 extra.
This all 3" bridge & tube kit will flow what you need on the LLY! It includes a port for your boost gauge. The OEM bridge is opened up inside and a flow divertor welded in for better flow. It also deletes the EGR so it's Off Road Only & best when used with a 3" boost tube.
This kit adds an amazing 85% increase in airflow over the stock LLY components!
There is a $100 core charge for the OEM bridge included that will be refunded if you return your old bridge CLEAN within 2 weeks.
