figment
A junkie for the purr of a 6.5L
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). Cranks but won't fire, no CEL, No WTS light, Plugged in diagnostic tool (paperclip) CEL won't flash.
- Year: 1995
- Truck model and class (ie: c2500) Tahoe LT
- Automatic or Standard? Auto
- Mileage: (indicate miles or km) 285,000 km
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) Pmd, #5 resister, Replaced Lp and OPS @ 276,000
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? S model, turbo, Egr still in place.
- Ambient outside temp: (indicate *C or *F) -5 deg C
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) What ever regular low sulpher is.
- What fuel additives are you using? Syn 2 cycle oil, 1 liter for every three tanks.
- Where are you located? Saskatchewan, Canada
- Air filter @ 275,000km
- Fuel filter @276,000km
- CDR Valve? DK
- Coolant – last flushed/replaced at 272,000km
- Oil – synthetic/regular, changed at Royal Purple 5W30 @ 282,000
- Batteries – state of charge, (matched set) replaced at, Matched @ May of last yr. Optima red tops.
- Battery cables and grounds (removed, cleaned and tightened): Yes
- Glow Plugs - how many miles on them? DK What type? DK_____________
- Injectors - last changed at? DK_______________
- What were you doing when it happened? Started it to go to work
- How was the truck running fine before this problem appeared? Like a champ
- Has this problem ever happened before? All problems as described above @ one time or another not all @ once like this.
- Describe any related factors that might be part of the problem. Having problems with my starter kicking out when the engine starts to fire on one or two cylinders
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) Y And? I get a blank CEL, won't light up at all
Diagnostics:
1] Starting:
1a] Does the engine start? N
1b] Does the engine crank over? Y
1c] Are your batteries fully charged? Y
1d] Have you removed, cleaned, and tightened all battery connections? Y
1e] Does your Wait to Start light come on for a time? How long? N
1f] Does your glow plug light come on? N. For how long? 0
1g] Do you see smoke from the exhaust while cranking? What color? N
1h] Does the Service Engine Light Glow during Start/bulb check? N
2a] Can you hear your lift pump working? N
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? N
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? Oil pressure comes up and no sound from the LP.
2d] Loosen an injector line and crank the engine - does fuel come out? Didn't try, on my lunch break._________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? Little bit, new fuel cap @ 277,000km___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) RM in bumper with heat sink
3b] Condition of Extension harness (if used) Vendor or Homemade? Home made, done with solder and weather proof shrink wrap.
3c] Condition of grounds / ground wires to IP / PMD. Check Harness.On top of the IP
3d] PMD Make: Stanadyne
3e] PMD Age: replaced @ 263,000km
4] Stalling Issues
4a] Do you experience stalling only when hot? Y
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) When idling for more than 10 Min.
4c] Does pouring cool water over the IP seem to help with restarting? Didn't try, started up with first hit with the key
4d] Is stalling momentary (engine recovers)? N
4e] Does SES light come on when engine hiccups? No engine hickup.
4f] Does cruise control quit working when engine hiccups? No engine hickup.___________
4g] Does re-starting seem to reset engine, restoring cruise and power? Stalled in my driveway.
4h] Changes to dash lights or instruments during stalling events? N___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? N
5b] Any bubbles or oil film in coolant overflow tank? N
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? N
5d] Excessive white smoke from exhaust on cold start? N
5e] Excessive black smoke from exhaust under hard acceleration? N
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? No Gauges yet.
6b] Maximum boost under load? IDK
6c] Have you added a performance PCM (reflash) or Chip? I wish, anyone got one for sale?
6d] Have you changed exhaust / downpipe / crossover? I wish, anyone got one for sale?
6e] Wastegate – mechanical or vacuum (OEM)? OEM, haven't found a spring i could use yet for a TM
7a] Single or dual thermostats? Single
7b] Have you replaced them lately? Manufacturer of replacements? N
7c] Have you pulled and cleaned Radiator and coolers lately? Checked them out right after I bought it @ 275,000km and the were clean as a whistle.
7d] Have you replaced the fan clutch? Manufacturer of replacement? Looks OEM
7e] (winter) Have you tested your antifreeze? Good to what temp? -45 deg. C
7f] (winter) Are you using a winter grille cover? Y
- Year: 1995
- CDR Valve? DK
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
