Little bit of LBZ maintenance before I get back into towing season
tanman_2006
Just a farm kid...
Seiling, Oklahoma
I need front end work again, I have kryptonite upper control arms, lower ball joints, all idler, pitman, and tie rod parts are new. Only things I have left to purchase are steering shaft joints and sway bar links part numbers and stores would be appreciated.
Next I need to get tuning and edge in site. Once again on a budget stores w/ reasonable prices welcome.
My intercooler boots are getting pretty nasty so I might go ahead w/ a pcv reroute and new rubber boots. Options welcome.
Last but not least I have a noisy idler, might as well do it and the tensioner, what part numbers are those.
Thanks for any help guys!
Should be able to get your info from RA and Dirty Hooker Diesel Tanner. I believe DMax store has some of the items too. I bought all my front suspension stuff from RA when I did my refurbish about 75 k ago.
I got my PCV reroute through DHD when they were All Seasons diesel. I wouldn't personally use anything but OEM for the idlers. Again, through RA is probably the better price. Sometimes you can shop part #s through RA and then find a better price for it through Amz or Ebay
Don't forget new engine oil can STINK! (New as in fresh oil change and the new EPA Stinks CJ4 formula) You may want to leave the PCV system alone. Some brands are so bad I've considered adding a CDR system to the 5.9.
