btfarm
America First!
I need to replace my 9006 low beam headlight bulbs and 9145 fogs. I don't want some super bright stuff but I'd like something better than stock that lasts a long time.
Suggestions?
Suggestions?
I would go with HID's. James is THE GO TO guy on light upgrades.
Honestly, unless you spend the couple $100 and do an OE HID Setup, the HID Kits out now aren't even worth it.
I mean hell, you can get an HID System for about $20 now. That's less than ALOT of Halogen Bulbs out now, that...chances are, will outlast the HID Kit, and cost you less in the long run (replacing Ballasts & Bulbs)
Here's the Philips Xtreme's, only $32: http://www.amazon.com/dp/B00BQWQLQI/?tag=jhuntlink-20
Mike, you were around when candlelight was reflected in a Lantern.:rolleyes5:What's the downside to these Silverstar units using stock wiring? I'm not in a mood to drop $50+ per bulb. Remember, I was around when halogen sealed beams were the new hot setup...
View attachment 42410 View attachment 42411
Good one, Leo!
hey Mike, you walked right into that one. However, I didn't say much because I remember Sealed-beams!
