rockfoot
In the schematic for a 1995 6.5 Sierra K1500, there is a wire coming from the Fuel Pump Relay to the "Fuel Pump Prime Connector". I am assuming that this wire is the wire that energizes the LP when the switch is placed in "Run". Where is the "Fuel Pump Prime Connector"? The problem is: the pump used to come on when I turned on the ignition... I realize that there is an OPS that maintains power to the LP while there is Oil Pressure present. But what gives the power (1995) to the LP prior to the oil pressure being present. (I am thinking it is the "Fuel Pump Prime Connector"). Is it the "Wait to Start" circuit? My fuel pump works when I jump out the relay. The relay works in the "Start" position. The relay is good. The truck is very hard to start and I really believe this is my problem. No problems once it is started. Thanks in advance, R. Barrett
