Ok, here is a fun intermittent one. Lift pump, relay, or OPS? It would be easy if the failing part stayed 'dead' and didn't come back to life after starving/stalling the engine for fuel. :mad2:
I have a OPS relay bypass wired on my 1995. This has the OPS powering a relay that powers a 4 Amp Mallory lift pump. I lost power twice traced to the lift pump not running. I caught the lift pump in the act once not running. I was able to jump the factory lift pump relay (this is not the bypass OPS relay) after the engine stalled out and the lift pump started running. Then the entire system continued to work normally.
Powering the bypass relay appears to work and start the pump every time.
So are the brushes in the Mallory about to fail? Is the OPS going intermittent or is the relay the OPS powers going out?
I replaced the relay, but, as it was cheap and easy to get to it is not likely the problem... :rolleyes5:
