I check my lift pump from time to time. Today it was giving me hot no start issues. Even stalled after starting. White smoke while cranking. Water on IP and shorting the GP controller almost did not help.
Finally started and lift pump was not making noise. Jumped pin G and it was clacking away loudly. With 1 PSi and I could pee faster that it's output from the drain valve...
The Autozone replacement, my price $50.00, is putting out over 10 PSI as my gauge readings stop there. Guessing less than 15 PSI from the extra range on the pressure vac guage.
Any advice on return line problems plugging up? Other things that may cause high pressure? Is the high pressure even a problem? (Was 7-8 PSI when the old pump was working.)
