95 gmc with the 6.5 truck started bucking and coughing and dying running its self out of fuel replaced fuel pump relay and did not help put test light on lift pump and it only has power fed to it when the ignition is in the crank position, and no other time it is my only vehicle so for the time being i ran a toggle switch to lift pump and it runs fine. i dont know what tells my lift pump when to run i am guessing the pcm controls it but not sure, any help would be greatly appreciated
