turbopower6
Hi All,
I should be billing GM for my "engineering" time as I redo the fuel supply side of our 96 6.5 Suburban.
Has anyone used the AC-Delco Lift pump part # EP 1000? I spoke with Ac-Delco in MI today and they told me this is speced at 8-12PSI @ 13.5 volts (+/- 1 volt) and flows 21 GPH.
The OEM lift pump is the EP 309 that specs out at 2 PSI @ 13.5 volts (+/- 1 volt) and flows 23 GPH.
On this site I have seen posts for the EP 158 which specs out at 9-14 PSI @ 12.0 volts and flows 22 GPH.
I am plumbing both a frame rail LP and the Walbro FRB 5 in parallel to end the nonsense of retarded fuel supply once and for all. I am looking to do this once and not come back to revisit it again.
Thoughts?
Thank you,
Ted
Thoughts?
Thank you,
Ted
