matuva
Tropical 6.5er
IIRC, on the 1996+ 6.5s, while you're doing glow cycle and waiting to start, the lift pump is powered by the PCM. Once you start the engine (successfully
), the PCM quits feeding the LP, and the power to LP is going through the OPS.
On 1995 and backwards 6.5, while you wait to start, the LP is not actuated, waiting power from the OPS once the engine runs and oil pressure is established.
Any of you already tried to wire a parralel power circuit to LP which will feed it once you wait to start, and then leave place to the OPS when engine runs, sale so as a 1996+ ?
Nothing critical, but I really prefer LP pushing fuel to the IP when crancking, rather than IP having to suck fuel at this moment...
