12ga diesel
Jack of all, Master of none
With how my truck sits right now at it's stock height, all I really want to do is put a leveling kit on it to raise the front end up a couple inches. My main question is what do you all think about these couple different options. The first one is made of a polyurethane material that I would think would make a pretty big difference when it comes to sound. But will these last as long as the ones made of steel?
http://www.xtremediesel.com/daystar2comfortridelevelingkitkc09101bk.aspx
These next ones are the steel ones. Being that they are made of 1/4" thick steel, I can only imagine that these would last much longer then a rubber type.
http://www.xtremediesel.com/readyliftsuspensionlevelingkit66-1090.aspx
What I am looking for are some suggestions on either ones. Right now I think I am leaning towards the second ones (the steel ones), but quite honestly, I am still up in the air about either one.
Another question, the Daystar ones come in a 2.5" type as well. Would this put the front of the truck at a more true level stance or would it sit up a half inch?
