LED Cargo, Reverse, and Interior Lights added
BoostN
Staff member
Administrator
Tennessee
Took some time this weekend and worked on the truck..
I added the Cargo, Reverse, and Interior dome LED lights. Truck has a cleaner and more modern look to it now.
Here are a few pics
Notice the difference on the Interior dome from the Front (LED) to the back (Stock).
Here are the reverse lights. I can't really tell if they are brighter honestly. I may try a few different ones and see what works.
I didn't get a picture of the cargo, I'll make sure I do that tomorrow.
I'm now looking for a set of strips for the footwells to see how it looks lit up. Just to try, it may be to much light.
PS... Pardon the new garage mess.
V-leds are definitely pretty bright, but I've been through 1 set of license plate lights and 1 rear stop lamp already. I would think they would last a bit longer.
v-leds.com
That's where I get all mine, and they really are the Brightest On the Market...that I've Found so far.
Well, now I will say my LED reverse lights look great, but I think the stocks are brighter. Any links for something else James? Factory bulbs are 921 in my reverse ones.
Ouch.. $50 bucks though..
But, I guess that explains a lot. Mine was only $10/pair. :D
Yea, if you can Swing the Price, IMO, it's Worth it. Then you can also do a Comparo. and see that with LED's, as with ALOT of other things, you get what you Pay for.
Link me to the ones you got from Super Bright.
http://www.superbrightleds.com/vehicle_led_bulb_finder.php
Select my truck, and it's the 921s...
This: 921-x9: Wedge Base LED bulb
Edit: sorry put the wrong one up.
Oh man, just Looking at the LED Layout, I can tell they are Dim as hell, and not really Optimal for your Housing. The LED's Shine Straight Forward, there are none around the Perimeter.
The Cheapest ones that V-LEDS has that'll Work for you are these: http://www.v-leds.com/Exterior-LED-...LED/2-6K-WHITE-25-WATT-HIGH-p9595898-1-2.html but they're outta Stock.
You're not kidding.. I'll probably go ahead and get the $50 pair..
