DennisG01
The fuel return line fitting (top most one in picture) is looking pretty nasty and it appears that is where the new "waterproof" spot on my driveway is from. I plan to drive it to work tomorrow and then pickup some rubber (probably not actually "rubber") fuel hose on my way home. I'll cut out the fitting and the rusted section of hard line and use clamps (double clamp, turned 180*) to temporarily fix this. Does this sound OK?
From what I can find out, I need to make sure I get fuel hose that is compatible with diesel as it would be different hose than gas?
For a more permanent fix, could I just flare the end of the hard lines -- sort of like making a "barb"? http://www.harborfreight.com/7-piece-tube-flaring-kit-5969.html
This return line isn't under any type of real pressure, is it?
Driving it the way it is, the worst case is that I lose some fuel, right?
