Mad Maxx
See, what had happened was...
Just got done with the Install. Took me about 30-45 Minutes.
New Banks Pipe went back in EASIER than the OEM one came Out, and it's Bigger too. Go Figure.
But yea, I Expected a lil bit of a Gain from putting this in, but I was way Wrong. This Pipe really does make a Big Difference. When I Floored it, I def. had to use more Neck Muscle to keep my Head Straight than I used to with the OEM Pipe on. Top End is Sickening now.
This Pipe is 100x better than the AFE one, for one Reason....the Turbo Connection. The AFE remains the 2.5" Diameter, then just Jumps right to 3". It does this so you can Re-use the OEM Coupler. The Banks Tube is 3" from End-to-End, and come with a New Coupler that is 2.5" on the Turbo End and 3" on the IC Tube end, but Tapers from 2.5" to 3" right at the Turbo Exit, so as soon as the Air is coming out of the Turbo, it's Expanding up to 3" and Flowing like mad.
Every Range of the Power Band is Improved with this Pipe.
Def. a "worth it" Mod.
Ordered it Direct from Banks.
