Mad Maxx
See, what had happened was...
Yep, this is another Mod that doesn't look like much, but Adds a Nice Kick in the Truck.
It's like the Turbo is on an On/Off Switch now. It's Bad, but inna good way.
I can't go past 1/2 Throttle now or I'm Spinning the 24's. I can Break them Loose at 50mph now.
Install was really easy. Again, like the IC Tube, it took Longer getting the OEM one Off, than it took Finishing the Install with the New stuff.
Only I don't really like, is the Intake System isn't as Solidly Held anymore, as it is with the Solid OEM Elbow. The AFE one uses a Silicone Coupler between 2 Joints, which makes the Intake Wiggle around a lil bit now. It shouldn't be a problem though.
Turbo Whistle seems Louder too.
~THERE IS ABOUT A 24GA WIRE THAT IS BEHIND THE MOUTHPIECE. BE VERY CAREFUL WHEN REMOVING / RE-INSTALLING THE PIECE SO YOU DON'T RIP THE WIRE. IT LOOKS VERY FRAGILE AND EXPENSIVE.~
So all-in-all, yep, this is another Mod that should be done. :thumbsup:
Here it is, they should be In-Stock at all Places now: http://www.xtremediesel.com/afepowerbladerunnerturboinlettube46-60039.aspx
