think of this in your mind to the old little kids ditty...
the LP is connected to the relay...
the relay is connected to the ops...
and ops is located to the... uhhhh, ahhhh where?
Decided to roll under the truck yesterday to check some voltages before I get into replacing the lift pump, etc. My voltages were taken with the lift pump still connected to the wire harness, because I read somewhere that disconnecting the pump could give faulty readings. My readings were about 8-8.4vdc spinning, and just a touch over 3vdc running. That just does not sound like enough to properly run the pump. My plan is to replace the ops, which is located where? I also plan to add a relay to the circuit, that will fire the LP whenever the engine is turning over/running. Does that sound like a good plan? I have also read about bleeding the fuel system via a brass t-handle valve. This valve is located where?
Thanks for all the tips guys! I need to get it running right, and soon. My little crippled up buddy needs to be moved from Oliver Springs to Rockwood in about 4 weeks, and I would like to have the truck running right by then... and I will give you two guesses who will be doing the move.
