treegump
Romans 3:22-24
Passenger side last night. I thought it had previously been separated from knuckle when I did my ball joints and steering linkage, but I broke 2 sockets and an adapter before I ground down a 15mm impact socket.
Question though - When I put it back together. I could spin the hub freely - yea, there was quite a bit of resistance, but I could spin it by hand. When I got it on the knuckle and tightened the backing bolts to 59ish lbs, the only way I could turn the hub was with some leverage - and then again, it was an evenly tight resistance. When I got the tire on, it spun more, but again - the same resistance.
I got the hub assembly from Bumper-to-Bumper and it was a Comko...or something with a C. Guy there (its got a small town feel - kind of like carquest feel - they still smoke in there, place isn't sparkling, a guy that gets dirty working on his vehicle is comfortable in there) said that he's/they've never had complaints/problems with the bearing.
I still feel a slight vibration...but it may be my imagination. After driving 5 or so miles, I got out and felt the hub and it was cool to the touch My buddy recommended when I get home tonight, to take the tire off to see if I can spin the hub by hand and if not, then to take it apart and try and clean up the surfaces...maybe something not quite smooth.
Also - it seems like if I unscrewed the lower left bolt (if looking at side of vehicle (passenger side), then the hub would at least be loose enough to turn by hand.
Any experience, thoughts, ??
Sorry for the lenth - thanks for the help!!
