matuva
Tropical 6.5er
Hi,
we have a 6.5 experiencing erratic revving, especially when tranny is on D or rear position, parked or while cruising.
Nothing happens when on P or Neutral.
The engine idle and run a bit rough, but we found, by doing injector balance with AE scanner, that injector # 6 does not respond to balance, not sure wether is has failed (stuck opened or closed) or if it is the IP failing.
Enclosed is a screenshot of the AE screen while scanning for DTCs.
There are DTCs refering to IP, and others to tranny.
What's your opinion guys, especially about erratics revving which are a bit dangerous...
