I need to get a bigger jack for the truck since my other jack is only a 1.5 ton low profile jack. I've been looking at 3 and 4 ton jacks but not sure if I should strictly look at 4 ton or if I can get away with a 3 ton. I'm guessing a 3 ton should be plenty but thought I'd ask you guys to see what you thought. I've also been looking at lift ranges as much as anything else. Seems most are in that 19-20" range but I'm wondering if I lift the truck later down the road how much jack it's gonna take to get it up in the air. Not a big fan of stacking 2x4's on the jack pedestal but I've been known to do it.
