Word was that it had a unusual noise start like a ping that went away when the driver got off the throttle. Then it cut loose with smoke out the exhaust and under the hood and stalled.
It still ran when I bought it, but, not that well. http://www.thetruckstop.us/forum/showthread.php?25281-New-toy-in-the-driveway.-1995-Surburban.
This is the tear down. We knew it was iffy with the sludge oil. Dad got the accessories off in 1/2 a day and 94blazer and I ripped this down Saturday.
Then the rust on the driver's side wasn't a good sign.
Then the push rods on the passenger side had us going :WTF: with the valve springs and valve stems looking ok.
Getting the head off made us think there was a bad injector. That is not carbon build up, but, aluminum build up. As guessed in the other thread two pistons at TDC is a bad sign! You can see the outline of the valves in the piston crown.
Getting the oil pan off with a rubber mallet sounded like broken glass being knocked out. :skep: The oil pickup screen is a little clogged.
I am starting to get a bad feeling about this now. The rod is not broken for TDC x2.
Using a 10 pound sledge and other ways to convince the piston to loudly leave the cylinder... Top and bottom if you can tell...
Then it gets really bad!!! :suicide: 4 separate holes and a crack between them.
Finally a pic of the bent push rods and connecting rod.
I wonder if this can be sleeved? :rof:
