I am replacing the optical sensor on my 98- 6.5. There is what looks like a pointer on it & the bolthole is elongated. Is it adjustable & if so how do you do it?
Well I guess I screwed up already I already took it off!! I will check out optic bump. THANKS !!!
Then look at your fuel at eat idle it should be around 7 to eight maybe even 9 mm3 if you are on the money.
