I measured the vacuum the IP pulls with a dead lift pump. I plugged the combination pressure/vacuum gauge into the fuel bleeder outflow hose, so this is measuring vacuum at the dirty side of the fuel filter, attenuated by about 18 feet of hose and the bleeder valve. Next step is to repeat these measurements on the IP side of the filter, where the vacuum will clearly be higher.
4 HG @ 725 RPM @ 0 MPH -- Idle
3 HG @ 1350 RPM @ 10 MPH -- Steady
5 HG @ 1750 RPM @ 37 MPH -- Steady
6 HG @ 1700 RPM @ 48 MPH -- Steady
9.5 HG @ 2800 RPM @ 60 MPH -- Accelerating
Since these pressures can clearly go negative, I can't understand why folks would install a pressure-only gauge here. It seems to me to call for a combination vacuum/pressure gauge like PN 56480809 at mscdirect.com, an Ashcroft 30-HG to 15-PSI gauge. 30-HG to 10-PSI would be better, if you can find one. The one I'm using in the picture is the right range, but it's more a tool than a permanent gauge.
