IP Timing OBD2
matuva
Tropical 6.5er
I'm using AE software for that.
ECT at or above 180° F
Most of the time, using Time set and TDCO learn commands, I succeed setting the TDCO at the value desired by the owner (-.05, -1.5 or -1.94)
What confused me, is that I never succeed having low value at desired and actual timing, +3.5 to +8.5
I can get values fluctuating around the +3.5 during time set, that makes very quiet engine, but it goes up as soon as I close time set command.
Most of the time, these values stay around +10 to +11.5
What am I doing wrong ? Would I have to perform a koko routine each adjustment or time set and TDC learn are doing the same ?
Would turning the pump slightly to pass side give a lower des. act. value?
not really, but that does change TDCOffset value as the pump is retarded.
I believe TDCO is doing the same things as KOKO with the exception you can control what it is set at.
I think so, but may be the koko is more efficient ?
The timeset is the ONLY time you will see 3.5°
The PCM controls the desired timing during operation/idle and anytime other than during timeset, moving the IP will not change it at all. Most stock programs are around 8.5°. If when you enter timeset or TDCO it revs to 1000rpm that would explain why it might be at 11° when you see that. Some aftermarket programs or maybe even some factory programs will have it set to 11° at warm idle.
OK, thanks for the highlights buddy.
Gonna care about TDCOffset only, one goes with the others anyways, I mean IP position will generate actual timing and TDCO values anyways, so, as long as I get satisfied with TDCOffset value, I should be right ?
