Soooo... It runs, idles and drives fine until it warms up? After it warms up it idles fast. Has a off idle power loss with white smoke. Once past 1600 is clears out and runs fine?Fine to 180 water temp then idles fine between 1000-1500 rpm heavy white smoke low power to 1600 from there runs fine.
Any Ideas
Thanks
Disconnect the sensor the engine runs higher idle and runs perfect when up to 180 plug it back in and loses power timing go off. Pulled the fuse for ecm put it back in and run with the temp sensor out, no codes.seems to me the computer is making it change time because of the temp readingmight try ohming out the temp sender in the coolant crossover. there's a chart here somewhere
I think I have fixed the problemDisconnect the sensor the engine runs higher idle and runs perfect when up to 180 plug it back in and loses power timing go off. Pulled the fuse for ecm put it back in and run with the temp sensor out, no codes.seems to me the computer is making it change time because of the temp reading
Thanks
