Problem: Explain your problem in concise language (ie: Cranks but won’t fire). _Intermittent stalling then hard to start, if it will start at all. Always starts again after sitting for a few hours or overnight and will run for a day or two before dying again___________________________
- Year: ____1998__
- Truck model and class (ie: c2500) _k3500________
- Automatic or Standard ______standard____
- Mileage: (indicate miles or km) ____215000_____
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ____unknown_______
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _don't know which engine, turbo_____________
- Ambient outside temp: (indicate *C or *F) ____50*F______
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ____#2_____
- What fuel additives are you using? _____lucas______
- Where are you located? ______north central texas_______
- Air filter ___2kmiles ______
- Fuel filter ___50 miles______
- CDR Valve? ___unknown______
- Coolant – last flushed/replaced at ______unknown_______
- Oil – synthetic/regular, changed at _____213000______
- Batteries – state of charge, (matched set) replaced at ____205,000_________
- Battery cables and grounds (removed, cleaned and tightened): ______unknown________
- Glow Plugs - how many miles on them? _____unknown____ What type? _____________
- Injectors - last changed at _____unknown__________
- What were you doing when it happened? ______in-town driving________
- How was the truck running fine before this problem appeared? _____no major problems, black smoke on hard acceleration________
- Has this problem ever happened before? __________nope_____________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _n___ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? ____most of tht time_____
1b] Does the engine crank over? __yes______
1c] Are your batteries fully charged? __yes_______
1d] Have you removed, cleaned, and tightened all battery connections? ___yes_____
1e] Does your Wait to Start light come on for a time? How long? ___no______
1f] Does your glow plug light come on? ___no______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? ___no_____
1h] Does the Service Engine Light Glow during Start/bulb check? ____yes____
2a] Can you hear your lift pump working? ___yes_________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ___yes______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ____stock on pump_______
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: _____unknown______
3e] PMD Age: ____unknown_________
4] Stalling Issues
4a] Do you experience stalling only when hot? _____no_______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ___no___
4c] Does pouring cool water over the IP seem to help with restarting? _____unknown____
4d] Is stalling momentary (engine recovers)? ____sometimes_____
4e] Does SES light come on when engine hiccups? ___not always______
4f] Does cruise control quit working when engine hiccups? _____unknown______
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ______no_____
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? ___no____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ____no______
5d] Excessive white smoke from exhaust on cold start? ___yes______
5e] Excessive black smoke from exhaust under hard acceleration? ____yes______
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? _____no______
6b] Maximum boost under load? ______unknown______
6c] Have you added a performance PCM (reflash) or Chip? ______no________
6d] Have you changed exhaust / downpipe / crossover? ______no__________
6e] Wastegate – mechanical or vacuum (OEM)? _______oem_______
7a] Single or dual thermostats? _____single_______
7b] Have you replaced them lately? Manufacturer of replacements? ____no_____
7c] Have you pulled and cleaned Radiator and coolers lately? _____no_______
7d] Have you replaced the fan clutch? Manufacturer of replacement? ___no_____
7e] (winter) Have you tested your antifreeze? Good to what temp? ____no______
7f] (winter) Are you using a winter grille cover? _____no______
I've had the truck for a less than a year, the guy I bought it from used it to tow his 5th wheel with it. interior is immaculate. It's had a lot of miles put on it but i've tried to be pretty easy on it. haven't towed with it yet, not even any heavy loads(over about 500 pounds in the bed).
this started last week, it just died. thought my fuel gauge was malfunctioning, and put more fuel in it, but that wasn't it.
ended up pulling th Fuel filter and replacing it, it ran really well for a day and then stalled again. Put a bottle of SeaFoam in it Just In Case, but it died the next day again. now it does it all the time, but intermittently. I *think* its the IP but maybe it's just the PMD? I don't have access to a code reader, does anyone have a different idea, or do you agree that it is probably the IP or PMD?
thanks in advance,
Perry
- Year: ____1998__
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
thanks in advance,
Perry
