mohawkmike82
Hey guys I've got some gremlins
-I have to cycle my key between 5 and ten times to get my wait to start light and glows fired. L/P primes as it should every time key is cycled. Once engine fires i usually do not have cold fast idle unless i blip the throttle at which point it will fast idle until warm.
Glow controller is about a year old Napa Echlin brand. Grounds have all been taken apart and cleaned, connections look great.
Codes are P0380 glow circuit problem
P1216 Fuel solenoid response too short -- Swapped out spare PMD with no change in symptoms
P1656 Intake CMP actuator solenoid control circuit -- Vaccum wastegate code?
Truck runs great with lots of power. Throttle is very touchy and does not pass the idle - 2500 - idle test. I believe this pump to be tired and on its way to I/P heaven. Just wondering if these few gremlins are connected to one problem as they surfaced together with the exception of the touchy throttle.
Any help suggestions is appreciated!
