monkeywrench0786
- Messages
- 11
- Reaction score
- 34
For sierra 1500 , 2500 hd and Duramax owners that have that ugly mismatched panels, Glidden interior paint peppered pecan makes the interior feel warmer and new again, you'll need to use plastic safe paint remover as the paint GM used will lift wrinkle and look horrible., spot test a good paint remover to make sure it doesn't melt surface, I used brake fluid let sit for a six pack and wiped it all down wash w hot water and dawn platinum dish soap, a self etching primer is recommended, average coverage is 4 passes w a 20min break in between for best results. At 70+ temp w humidity around 35%. Hope this helps someone that wants an interior upgrade on the cheap.
