Interchangable injection pumps
Norway
Hi.
Is it going to be a problem swapping the injection pump from a 1995 year into a 1997 year Silverado? Blew the engine in the 1997, donor engine is out of a 1995. If I've to swap the pumps I'll do it before the 1995 engine goes into the 1997. Thanks so far.
Norwegiandiesel
@tanman tanks.
Yep, the 94 is odd I believe. Don't or didn' know if the 95 is odd as well, because they're both OBD1?
any pump will interchange, except the DS4831-5068 which was specifically designed, for the 1994 K3500 IIRC, and which needs it's OWN ECM to work.
A 1995 OBD-1 will work fine with a 5067, 5289, 5521 or a 5521S, and your 1995 IP will work fine in your 1997 OBD-2
@matuva-thanks.
You seen to be absolutely certain on this subject, thanks.
By the way, how expensive was the no gap rings?
Thanks
Ole Tom
x2 with the only other comment being some 2500s had them too.
You're welcome ;)
The no-gap rings wher a bit over $300. The n°2 rings were machined to make them gapless, and I get the stock top rings and bottom rings with them.
Leroy from Leroydiesel.com was very helpful and arranged everything to provide me with a full set
