Matt Bachand
Depends on the 6.5
I have a new set of traditional intake gaskets that I got from E-bay ready for my fuel pressure gauge install. I will be removeing the intakes to do some house cleaning and get a easy shot for the gauge install, (which btw looks awesome in hand, Stewart warner 114214 white faced, 0-15psi)
I still have some right stuff left over from my oil pan install which doesn't leak a drop.
Over the years I have done the intake gaskets a few times, and I don't think i've been 100% successful at leak free.
My question, as the title suggests, should I use the permatex or use the traditional gaskets??
Thanks guys.
I look forward to the gauge install, as then I can finally replace my Rear tank sending unit to fix fuel gauge and give me 500+ mile range between fill-ups. Been along time waiting...
Racor/walbro install to give me old lift pump to replace dead one.
Removed sock in front main tank to avoid gel-up problem last winter due to gasoline sock.
Install FP gauge to have, and to avoid worrysome diagnoses of rear tank back in service.
Replace Rear LP with old Delco one that was replaecd by Walbro.
Finally replace rear sending unit to complete my fuel system overhaul.
I am going to buy a tube of marine grease (extremely salt resistant) and cake it on top of both sending units, as my new front tank sending unit rusted up after one winter......................
A few months ago I was running this pig with 100 mile range between fill ups... Now i'm at 250mi, and soon be 500+ with a working fuel gauge, fuel pressure gauge, more polished fuel system/water separation (racor)...
Good base for Heath regular pop injectors, hopefully before winter.
I could double that range to 1000+ if I fill my transfer tank too (50 gal)......
Thanks guys.
Thanks guys.
Thanks guys.
