jamierayo
Enter Witty Title Here:_____
What's the "normal" range for IAT's in a 6.5 turbo? I was thinking about getting a gauge for the 3rd pod in the pillar mount.
How hot is too hot?
How hot is too hot?
Who did you order your intercooler from and how much did it cost?These days with outside air at about 50 deg F and running empty my IAT on the freeway will run around 120 - 140 at about 4-7 psi boost. The problem I have is loaded climbing a hill. I can peg my 280 deg gauge and my Scan gauge only reads up to 299 if I have the trailer empty or loaded climbing a slight grade. Of course the PCM pulled the fuel off way back around 210. So, even with the reduced fuel input I can still run temps into the high 200's. After all I've been reading, that's why I ordered the ATT. It shipped today and I'm looking forward to next Friday when I can install it. I'll decide this summer if I still want to add the intercooler but from what I read, I can sell it.
On another note, the 150 degrees is rumored to be optimum for mileage. It would be interesting to put a heat exchanger in so you could actually control the IAT to a preset temperature and confirm that.
Too many projects...
You could do a set of shutters over the Intercooler kind of like the old big rigs had. That way you could adjust temp by adjusting airflow.
ambient air about 70f, no load- truck only at wot with att it hit 216.1, cruise at 3.5 psi, temp was 147. using gmtdscantech
